Error in Power Automate with Jira Connector
Marcel Wimmer
March 1, 2023
in Power Automate i get an Error with the Jira "Create new issue V2" connector.
Error is:
The dynamic operation request to API 'jira' operation 'ListIssueTypesFields' failed with status code 'BadGateway'. Error response: { "error": { "code": 502, "message": "Field 'reporter' of type 'user' is not supported.
What i unterstood is that i have to set the "Reporter" Field in the Issue Type to "optional", but i am not able to do that in the Project/Issue Type Settings.
Hope someone can help me.
Thanks in advance
Marcel
Jeff Dean
September 19, 2024
A colleague just told me the answer to this.
If the Jira credentials you are using have access to update the "Reporter" field on the issue, it will throw this error.  If you have that update-Report permission removed and just let it default, the connection should work.
chad_leblanc
This! This is the correct answer!  I changed my permissions to remove that and it worked like a charm!
Franklin
February 11, 2025
Hey Chad,
May I know how you did that?
chad_leblanc
I am part of a Company-Managed Project, but had Project Manager permissions on my board.  I made sure there were others that can manage the project outside of me, and once I removed that permission, it worked like a charm!
Im going to be working with my Jira Admin a bit more on setting up a separate permission to change that field, but because I am using my API key in the flow, it's going to default me to the Reporter field and my other admins can change the user after it hits our backlog.
Like Franklin likes this
chad_leblanc
I had run into another issue after that, however, that required my page layout to be changed.
We had a set "Release" field as mandatory on creating new stories, but it was going to the backlog anyways - had to remove that from the screen layout and then that worked great too!
Michael Court August 27, 2023
Hi @Marcel Wimmer,
I have had the same issue (I believe it's because the Jira connector cannot handle certain field types) and have been able to work around it by using the HTTP action instead. See here for a guide to get you started.
BK Gmail
March 2, 2023
Not an answer but I am running into the same issue. It had to have worked at some point, or I would have never been able to save the flow. I ended up deleting the Create a new issue (V2) and adding it back.
Fixed for now, but I lost the ability to pass extra fields from SP to Jira, as there is no JSON window available now. Maddening.
Marcel Wimmer
March 23, 2023
Hi Benjamin,
das Problem hat sich bei mir erledigt. Wir hatten noch das "Standard" Helpdesk Template als Projekt im Einsatz. Wir haben uns durch den Jira-Support das ITSM Template freischalten lassen, ein neues ITSM Projekt erstellt und dann hat der Connector auch funktioniert.
LG Marcel
