Great that you found the third party app that you need to remove from your env after my suggestion.
If my suggestions helped you, please click on "Accept answer" against my posting, so others with similar ask will see this is an answered and resolved entry.
Best, Joseph
Thanks for your help @Joseph Chung Yin I have found that my issue was the Gant app needed uninstalling to stop these from appearing :)
Welcome to the community. In JSM - Request type is based on issue type. Typically, there is not issue dependencies setup.
Issue Dependencies is for Jira Software application projects (to support Advanced Roadmaps for Jira) or Jira Work Management projects. They are not for JSM projects based on my understanding/experiences.
Issue Hierarchy is for Jira Software application projects (to support Advanced Roadmaps for Jira)
So it is not clear on what you are asking for?
Hope this helps.
Best, Joseph Chung Yin
Jira/JSM Functional Lead, Global Technology Applications Team
Viasat Inc.
You need to check your request type configuration (screens) and the issue type screens configuration setup.
What kind of project type is your project?
Best, Joseph
Hey @Joseph Chung Yin so I have tried editing/configuring the screen schemes but there is no option for "Issue Dependency" and "Issue Hierachy" to remove them?
What kind of project type your are using? Secondly, what you are seeing seems to be not out of the box. Are you also using third party add-ons? If so, you may want to look into those add-ons where those fields may be coming from.
Best, Joseph
