How to add multiple values to Insight post script
Eric R Hartway
I'm using the "Set the value of an object attribute with a predefined value" Insight post script.  It's very useful, but I'm having issues setting multiple values at once.
Followed these instructions:
Pressing the Enter key simply updates the post script.  Is it possible to supply multiple values?
Thank you,
Eric
PD Sheehan
February 16, 2022
The link you posted appears to be for Cloud version.
The server/datacenter version of the same page appears to be https://confluence.atlassian.com/servicemanagementserver/post-functions-1044784443.html
In this one, there is no mention of allowing multiple.
You can attempt comma-separated values.
If that doesn't work, you'll have to use the "run a groovy script" option.
Eric R Hartway
Thank you for the help.
