×I want to delete issues in Jira Service Desk that meet certain criteria. However, I can't find a "Delete Issue" action in the Automation UI.
These issues are getting created automatically when one of our systems encounters an error.
I'm able to manually delete the items, so I assume this is not a permission thing.
Hi @Ivan Wilson
Delete Issues option is available in the Automation action list, not sure where you are looking at.
Hey @Ivan Wilson , @Gikku is correct in their answer. Jira Automation has such an action. You might be getting it confused with Service Desk's internal Automation however?
Thanks @Simmo you are right, I was looking at the Service Desk internal automation. I didn't realize there were two types of automation. I've found the Project Automation menu and have set up my rule.
@Ivan Wilson do you ever get any timeouts from Jira when you run this rule?
I have a rule that updates Parent fields, deletes existing sub-tasks and adds a couple new sub-tasks....but I've been getting error warnings from Jira as follows:
Jira was slow to respond. Automation attempted to delete an issue, but the results of the operation are unknown. Most likely it succeeded.
More often than not the issues are NOT deleted.
i only can find the jira sevice desk automation UI.
where can i find the more advanced automation which allows deleting issues and has a scheduled trigger?
