How to deploy Project Automation with Configuration Manager for Jira?
Ashley Honeycutt
We have created some pretty extensive automation using Project Automation in our dev environment. Exported a snapshot using CMJ and imported into staging to find that everything but the Project Automation copied over.
Am I missing where in the settings I would include this in the deployment?
Thank you!
Walter Buggenhout
Hi @Ashley Honeycutt,
I am not sure if or how you could transfer automations using CMJ, but you can export your automation rukes to json format and then import them in another environment right from the global automation view:
Hope this helps!
Ashley Honeycutt
Thanks @Walter Buggenhout
I had actually tried that when I realized they didn't come over with the CMJ import, however most of them I can't turn on for some reason. When I click the slider to enable the rule it just slides back to disabled with no error.
SERVER
