How to generate a token with less than 128 characters?
The token I'm generating on the page below is too big, and my application doesn't support it:
https://id.atlassian.com/manage-profile/security/api-tokens
Is there any alternative to generate smaller tokens?
No, you'll need to code your application to support the length of tokens. (128 is pretty much a standard minimum length nowadays, and you should expect to see longer ones in the future)
I will do that, thanks!
