How to mark single sprints for setting automation rules in a multiple sprint setting?
Yvonne November 11, 2021
Hi everyone,
we have multiple sprints running in a project.
Now we want to set up an automation rule like 'if x then use active sprint y from Project A". But we can't differ between the multiple sprints in the project.
How can I set a marker for each sprint so we can select them separately in the rule configuration?
Your help would be awesome.
Cheers
Yvonne
Fabian Lim
Yvonne November 16, 2021
Hi @Fabian Lim ,
thanks so much for reaching out. This is indeed an idea but if I understood correctly it's only semi-automatic. Someone would have to manually set the Sprint ID, right? But this one changes after each sprint.
Is there another possibility for full automation?
Best
Fabian Lim
You will have to ask in the feature requests for this one.  It would make sense to be able to have a smart values for boards.
Or you can use scrpting via SIL or scriptrunner
Regards
Thanks @Fabian Lim
we will check again and otherwise open a feature request.
Thanks a lot for your support!
Best
