×I have a request type where they select a Project from a custom Asset Field. It pulls over multiple fields including a Project Issue Key. In automation run on create, I want to link my new request to the issue identified by my "Project Issue Key" field value.
Whether setting the Linked Issues field or using component Link Work Item, my only choices are Trigger work item and Most recently created work Item. Any suggestions on how to accomplish this?
Excellent... Here are a reference links that you may want to explore further as related to Smart Values
https://support.atlassian.com/cloud-automation/docs/jira-smart-values-issues/
https://support.atlassian.com/cloud-automation/docs/find-the-smart-value-for-a-field/
Hope this also helps you in the future.
Best, Joseph Chung Yin
Found my own answer but I'm not able to delete my question. What I found is I can paste code over the words "Trigger work item" even though it isn't clear you can do that. I used code {{customfield_12589.Project Issue Key}} which referenced my Assets custom field and the attribute that stored the key.
Hi @Julie Beltz
Well done, and...you may select your own post as the answer to the question.
And the rule editor is not great at indicating when a smart value may be typed into a field versus only using the dropdown. Instead one needs to just try it.
