Is it possible and how to create fields for users?
I'm importing users from Azure and would like to link with new user fields.
To do this
I need to know in the user's record, who is his Manager when imported from Azure.
You need to have Insight (Asset), which comes with the Premium plan of Jira: https://www.atlassian.com/software/jira/service-management/features/asset-and-configuration-management
Yes. You can take a look at the following links on how to create custom fields.
https://support.atlassian.com/jira-cloud-administration/docs/create-a-custom-field/
Best, Joseph Chung Yin
Jira/JSM Functional Lead, Global Infrastructure Applications Team
Viasat Inc.
Thanks for the feedback.
I didn't find in the documentation how to link the field to the user registry.
I need this field to appear in the Azure integration.
To integrate with your own IDP for users management, you will need Atlassian Access product - Please take a look https://support.atlassian.com/security-and-access-policies/docs/understand-atlassian-access/
Best, Joseph
Yes, today I use Atlassian Access for integration. When I link from Azure to Atlassian Access, I can't find the custom field I created. I think I'm not creating the custom field correctly.
This custom field must be part of the user's record.
In this case, I would recommend that you need to contact Atlassian Support (https://support.atlassian.com) for further assistance/solution. Please post their answer in this post if you can.
Best, Joseph
