Issue with Child Tickets/Subtasks not Copying Parent ticket
Kishor Mudhili
Hello Team,
how to copy information from Parent ticket to Subtask/child tickets using Automation Rules ?  could you please share the script
Marc - Devoteam
February 23, 2024
Hi @Kishor Mudhili
So within an automation rule based on issue creation, you would need to check if the issue is a sub-task, then you need to retrieve the paren and then you are able to copy informaiton from the parent.
Martin Bayer [MoroSystems, s.r.o.]
Hi @Kishor Mudhili , do you want to bind the operation to any action like "Parent issue updated"?
Kishor Mudhili
no. I don't want to sync anyting between both issues.  only when I tried to create ticket from Parent- all parent information ( perhaps Selected field ) should be copied to child issue.
@Kishor Mudhili ok, so you already have an automation which creates subtasks, is that correct?
Kishor Mudhili
@Martin Bayer [MoroSystems, s.r.o.] not created yet. im not sure how to create Automation for this . please help me
