I'm encountering an issue with the IdP-initiated SAML flow. When I attempt to use the IdP-initiated flow, I receive the following error from Jira's SAML callback endpoint:
{"key":"badRequest","context":{"message":"Invalid customer saml login callback request","reason":"SAML Request was not initiated by the service."}}
This error seems to indicate that the flow expects a SAML request, which is typically part of the SP-initiated flow. However, the IdP-initiated flow does not start with a SAML request.
For context, the SP-initiated flow works correctly without any issues. I suspect there may be a structural difference in the SAML response that is expected by Jira for the IdP-initiated flow, which is causing the problem.
Here is an example of the SAML response I’m using for the IdP flow:
Could you please advise if there are specific fields or configurations required for the SAML response in the IdP-initiated flow to be accepted by Jira, or if additional configuration is needed on Jira's end?
Thanks in advance for your help!
When troubleshooting "badRequest: Invalid customer SAML login callback request," it's worth noting that this error can be misleading in IDP-initiated SAML flows if the RelayState parameter isn't set correctly.
In your SAML authentication flow, ensure that the RelayState
parameter in the SAML response matches <baseurl>/servicedesk/customer/portals
, where <baseurl>
should be replaced with your actual public domain (e.g., yourdomain.atlassian.net/servicedesk/customer/portals
). This RelayState value is critical because it directs the user to the correct service portal post-authentication, and any discrepancies here can lead to the "badRequest" error.
Setting the correct, public-facing domain in RelayState
is essential for a seamless IDP-initiated login experience.
Greetings where do you set the RelayState? Is this in B2C or in Atlassian.
I am struggling to get this to work and have been dealing with it for over a week. I have followed Microsoft's guide to setup SAML in my custom polices. I am still getting the error in this post.
Any help will be greatly appreciated.
RelayState is a parameter in the SAML response sent from the IdP to Jira. To troubleshoot this, use a browser debugging tool like a Chrome extension for SAML (e.g., SAML Chrome Panel) or inspect the network traffic in your browser's developer tools. Look for the form data being posted to Jira from your IdP and verify the RelayState value.
Ensure that the RelayState parameter matches the expected URL format, such as <baseurl>/servicedesk/customer/portals
, where <baseurl>
is your public domain (e.g., yourdomain.atlassian.net
). If the RelayState is missing or incorrect, configure your IdP to include it in the SAML response.
Hi Roman,
I'm encountering the same issue, have you been able to resolve this issue going forward?
Kind regards.
Not yet, We are still working with the support to find a solution
Hi Roman,
I was using Entra ID for IdP, this was resolved after I reviewed all URL's in my IdP and Atlassian. (screenshot below)
For Atlassian's side, I used below mapping:
