Jira automation - set automation to return ticket to previous status
Lorenzo Cancelli February 1, 2023
Hi Community
I need help modifying an automation I already have in Jira.
Currently the automation works like this:
- the person handling the ticket puts it in a "delayed" status and sets an expiry date
- once the expiry date arrives, the ticket always automatically switches to a set status (so it always goes from delayed back to a specific status).
My goal for which I ask for help:
- Once the expiry date arrives, how can I set the ticket to go back to the status before I put the ticket in delayed?
I've seen that there is the option of Execute transition to 'same status (loop)', but I'm not sure if it works
thanks for the help
Hi @Sachin Dhamale
thx a lot for your answer
As you can see on the screen I have already set up JQL
It works correctly, i.e. when the due dates arrive the ticket is updated.
What I would like, however, is for the ticket to be moved to the status before it was put in 'delayed'. (of course when the due dates arrive)
Should I enter: "Copy from trigger issue?"
thank you for your kind reply
Lorenzo
Sachin Dhamale
@Lorenzo Cancelli
In that you can remove the "status = Delayed" from the JQL.
Hi @Sachin Dhamale
but if I remove the delayed status, no tickets are found and automation does not start.
I was just trying to understand if it was possible, once the due date arrived, to return the ticket from delayed to the status before it
in your opinion, is this not feasible?
thx
Lore
Sachin Dhamale
@Lorenzo Cancelli
Welcome to the Atlassian Community !!
You need to use the scheduler with JQL as a trigger and transition issue to specific status on action
Trigger > Scheduler > JQL  "status = delayed and expiry = now()"  Click the checkbox
Action > Transition issue to specific status
Accept the answer if it helps
