Setting up Automation rules for closing issues- can you set a resolution field type
Ann Marie Kjerland September 5, 2018
I've been using the automation rule to close issues waiting for customer info
but I'd like to set the resolution field with a specific values- any suggestions?
Deleted user September 5, 2018
You can change the resolution with a post function in the same transition that you have automated
Ann Marie Kjerland September 6, 2018
Thanks for the tip!  But not sure how to add the post function within the automation if then rule?
Deleted user September 6, 2018
I was talking about workflow post function:
Administration > Issues > Workflow > Transition > Post functions > Add post function > Update Issue Field > Resolution > Your value
You need to be a Jira administrator to achieve this. If the resolution must be different than the resolution of the transition you are using in this moment, just make a new transition with a condition which don't allow users to view it (but must be accomplished by the automation rule or it won't work).
For example, condition only users in group jira-administrator, and make that the default user a jira admin.
