Stakeholders for Problem Management
Bondili, Pushpitha Bai December 3, 2024
Hi Team,
Currently for incidents we have an option called "Stakeholders". So, is it possible to utilize the same field for problem as well.
Septa Cahyadiputra
December 4, 2024
Hi @Bondili, Pushpitha Bai
You should be able to create a custom fields for "Problem Management" with the same characteristics and usage. Then you just need to add the new custom fields into the ticket which allows you to build automation afterwards.
Hope it helps.
Septa Cahyadiputra
Bondili, Pushpitha Bai December 4, 2024
Hi @Septa Cahyadiputra ,
I tried the same scenario. But it is not working.
Septa Cahyadiputra
December 4, 2024
Can you elaborate what's not working on your end? I might not be able to help but if I can't other communities member might be able to assist you with the additional details.
regards,
Septa Cahyadiputra
