Transition Linked Issue in a Separate Project
Andrew Bilsdon September 28, 2024
Hi, I have a linked and cloned issue in a Separate Project that I want to Transition when the parent issue Transitions.Untitled.png
MC7-19 is the parent, MDS-25 is a cloned copy
I am using this automation
I get this
Which indicates that nothing was updated
Joseph Chung Yin
@Andrew Bilsdon -
I agreed with what @John Funk stated.  In automation rule, if the rule itself needs to touch issues from other projects, then the rule must be updated to include all the projects the rule involves.  Therefore, it is consider as a Global rule.
Another thing that users typically forget is to ensure the WF transition is defined to support the issue movement from status to status.
Hope this also helps.
Best, Joseph Chung Yin
Andrew Bilsdon October 6, 2024
Thanks Joseph, great suggestions to check re WF
3 votes
John Funk
Hi @Andrew Bilsdon  - Welcome to the Atlassian Community!
On the Rule details page - have you identified by projects? Or is it a single project rule?
Hi John, many thanks. When I look at the rule scope it is parent project
Do you think it should be a Global rule
John Funk
You will need to make it a multiple project rule and add the second project.
Like Joseph Chung Yin likes this
Thanks John, much appreciated
Like John Funk likes this
John Funk
You are welcome. Did that work?
Yes thanks John, Answer Accepted
John Funk
Great!
