I've created a webhook targeting an endpoint provided by a Power Automate workflow using the "When a HTTP request is received"-trigger. However, performing an action assigned to the webhook does not trigger the flow.
I've set up an identical webhook targeting webhook.site - a service used for testing webhooks - and that one works perfectly fine. Since the service logs the received request, I also copied it, removed the "host"-header and sent it to the endpoint using Thunder Client, which did trigger the flow.
I've had a conversation with a Power Automate support member, and they said that HTTP requests sent by webhooks are different from requests sent by clients. I can't really tell what makes it different, but I also can't tell what request is being sent to the endpoint exactly.
After a call with someone from Power Automate support, I was able to find the problem: The URL provided by Power Automate already had / encoded as %2F. After changing them back to /, the webhook triggered the flow successfully.
Hi @Jakob Gillinger could you kindly share the solution since I have this problem ?
About %2F -> / i resolved but still not works.
Thanks a lot in advance.
Roberto
I'm sorry, but that issue looks unrelated - after the fix I've mentioned, I had no further problems with my workflow.
Many thanks for the reply.
Yes I know it's not related unfortunately, but can you share your solution, I want to try if feasible.
For example, what did you insert inside these two red arrows?
Many thanks in advance
Roberto
Hey @Roberto Ialino,
I also struggled with somehow converting the Jira Connector to Power Automate.
The solution can be adapted:
"$schema": "http://adaptivecards.io/schemas/adaptive-card.json",
"type": "AdaptiveCard",
"version": "1.3",
"body": [
"type": "TextBlock",
"text": "[<key>: <summary>](https://jira/browse/)",
"weight": "Bolder",
"wrap": true,
"color": "Accent",
"size": "Medium"
"type": "FactSet",
"facts": [
"title": "Priority:",
"value": "<name>"
"title": "Issue Type:",
"value": "<name>"
"title": "Reporter:",
"value": "<displayName>"
"title": "Status:",
"value": "<name>"
Nice find! You'll find them hidden in the query params, not the main URL. For example, my URL was fine until the query param
sp=%2Ftriggers%2Fmanual%2Frun
which I then changed to
sp=/triggers/manual/run
and it worked! Thanks a lot for finding this!
