automation comment on jira not working
Sampath
Team
any body pls share the steps - automation rule for "when customer commented in the ticket" and to set "i am at OOO. Please contact xxxx" to notify
pls share the rule
Alex Koxaras -Relational-
Hi @Sampath
Can you share your rule and audit log please? Usually this should be pretty easy to achieve.
Sampath
Hi @Alex Koxaras -Relational-
Thanks for your response
I am working on UAT instance
When issue commented
If : issue matches JQL
 Then Add comment to issue
XXXXXXXXX
this what i have done in the rule but not sure if get expected result.
When customer comment when agent OOO ...automation reply sent to end sure to contact xxxxx
How do you define when your agent is OOO?
Depending on where you create this rule, it should look something like the following images (however, the condition of the agent being OOO is missing, since you didn't specify how you define on Jira the agent being absent):
Like Joseph Chung Yin likes this
Sampath
We have 3 shifts. Each shift 2 members. If any one agent planned for vacation leave and that ticket is not touched for 2 days or more than 1 day.....if end users put a comment about status updates - response comment should be "to contact xxxx"
Then you could probably check the update field or updateddate and put a condition on the above rules.
Sampath
Thanks for your response.
Possible to share the screenshot of steps, since i am new to JIRA admin testing all the scenarios in Jira UAT instances.
here in our organization - Reporter is a customer & Assignee is a IT Agent
When : Issue commented
If Reporter is Issue reporter
Add Comment : XXXXXXXXXX
Lakshmi
Sampath
Which keyword should taken Reporter(customer)  automatically {{assignee.displayName}} is this correct? pls advise
thanks
