moving issues from one project to another project
Hoc
I want to move issues from one project to another.
I've recreated the same fields on my new project but when I try and move its telling me to enter new values for the fields? I thought that if the fields have the same names it should be able to detect it automatically and copy it over?
I noticed that its also showing fields that shouldnt even be on the issuetype?
Any ideas?
Thanks!
Ollie Guan
Hi @Hoc ,
What kind of situation?
  • classic project to next-gen
  • classic project to classic
  • next-gen project to classic
  • next-gen project to next-gen
Hoc
Hey Olllie,
from next-gen to next-gen.
I also tried to use the 'retain' option and that didn't work either.
Ollie Guan
As far as I know, in next-gen projects, custom fields are completely independent, and you can regard them as different fields.So you need to manually match them during the migration.
Like # people like this
Jack Brickey
Correct
Like Nic Brough -Adaptavist- likes this
Hoc
What did u mean manually match them? As in manually set the value fora each field for each issue?
Thank you
Krister Broman [Advania]
September 17, 2020
Since you are mentioning recreating the fields i will assume that you are working with at least one next-gen project.
Next gen projects are not a good way to work in if you need to move issues between projects. Most data will not transfer between projects and will not be recreated see.
https://support.atlassian.com/jira-software-cloud/docs/migrate-between-next-gen-and-classic-projects/
So expect this data to get lost when you migrate between projects:
  • Custom fields
  • Story points estimation
  • Reports
  • Report history
  • Parallel sprints
  • Project and issue keys
  • Versions and releases
