Hi!
I see on every request in jira option for Reminders, it leads me to: My reminders for jira app, which is unsupported app and I am not sure how good it is. Do you have any experience with it or can you advice so good tool for setting various reminders on a jira project?
Hi @Vera Valshonok ,
My Reminders works although it is unsupported. It has been available for a very long time. It provides basic reminder features. If you need more advanced solution, I recommend our app, "Issue Reminders". It provides more advanced reminder controls, ability to send reminders to other users and Slack channels.
Deniz
Hi Vera,
Thanks for your question — this is a common challenge for many teams, and I’m happy to share a solution.
If anyone else is facing the same issue with unsupported reminder apps in Jira — we’ve built a reliable and fully supported alternative that’s worth checking out!
🚀 The solution — Reminder for Jira by Teamlead
We’re the official Teamlead | Atlassian Marketplace developers behind a range of Jira apps, with over 15 years of experience helping teams automate routine work and visualize processes more effectively.
Reminder for Jira helps you:
📝 Create reminders for any task — or even without linking to a task (just like a to-do list)
🔄 Automate recurring reminders — save time on repetitive work
🤝 Share reminders with your team — so nothing slips through the cracks
📆 Set reminders for subtasks and parent tasks — stay in control of complex workflows
⌨️ Use the "R" hotkey — to create reminders in seconds
💡 It’s fully native to Jira, plug-and-play, and works great for:
Support Teams — notify teammates about escalations, reduce resolution time by up to 25%
Managers — cut overdue tasks by 40% and boost team productivity
Personal Productivity — reduce mental load and stress with lightweight reminders
✅ Why choose Reminder for Jira?
Super simple and fast setup
Works perfectly with Calendar for Jira
Keeps your team on track without micromanagement
If you’d like to try it or need help, feel free to reach out at support@teamlead.one — we’re always happy to assist!
Hope this helps!
