HI,
How can I use smart Values in JSM approvals
thanks
Hi @Mohamed Saad Taha ,
please, what exactly are you trying to achieve?
Some info can be found for example here, section {{approval}}.
HI @Hana Kučerová ,
thanks a lot for your response for example if I want to use the approval of an issue to be the same approval in the subtask related to it
@Mohamed Saad Taha This could be possible with Approval required trigger - smart value {{approval.addedApprovers}} can give you list of approvers and you should be able to add them to the sub-tasks' custom field Approvers. But it depends on the situation, for example when exactly do you create the sub-task etc.
Hi, @Mohamed Saad Taha !
Due to the lack of information, I can suggest only to check the article to learn more about the approval workflow.
I agreed with @Hana Kučerová suggested. WIthout knowing more information about your ask, it is hard to provide you with the appropriate advise.
Best, Joseph Chung Yin
Jira/JSM Functional Lead, Global Infrastructure Applications Team
Viasat Inc.
