×Hi!
I've setup up an automation rule that applies a "template" each time a new Epic is created. The problem is that the Epic contains a table, I'm not sure how to apply this formatting. Here is an example of what I'm trying to add to the description:
XXX
XXX
XXX
[] Problem defined
[] North star metrics defined
[] Kick-off scheduled with required and optional stakeholders
Question | Answer |
Are there any sales or contract dates that the team should know or are working towards? |
How does this scale to other staff groups e.g. AHP, Nursing? |
Are there any known dependencies? |
Are there any new designs needed? Are there opportunities to remove any confusing UX flows? |
Should we displaying audit trails in the UI? |
Are there ways we can introduce better standards?
Are there any opportunities to pay down stale code or tech debt in this space? |
Will decisions in this impact performance? Design as this scales and/or app load? |
XXX
XXX
XXX
[] Problem or pain point alignment (stakeholder alignment)
[] Solution designed
[] Internal communicate of what’s in scope and what the phase(s) are
[] Solution built
[] Release notes drafted for external communications (stakeholder email, Beamer, QX release notes)
[] Update existing FAQs in Help Centre or create new page(s) when applicable
[] Testing included
[] Observability created to be able to measure (usage and/or data alignment)
XXX
Table markdown example:
||heading 1||heading 2||heading 3||
|col A1|col A2|col A3|
|col B1|col B2|col B3|
