connection between help center and software project
Ondrej Holubovsky
Hi everyone,
How can I add a link to the help center? I would like to have a shortcut from the software project.
I already created a clone rule, but I'm still struggling with the link to the help center and the issues
many thanks for your ideas
Nikola Perisic
Hi @Ondrej Holubovsky  do you want to have issues from software project linked to your service management project or to have a shortcut on your software that when clicked it leads to your service management project?
Ondrej Holubovsky
Hi @Nikola Perisic , the second one.
I would like to have a link on software, that will get me to the service management project (to the help portal)
Nikola Perisic
In your service management project, you can create automation rule:
  • Trigger - when issue is created
  • Clone issue action where you will select the project, issue type and summary -these are all required fields
Like Ondrej Holubovsky likes this
Ondrej Holubovsky
I done that, now every time I create ticket in service management, similar ticket is created in software project.
Unfortinetly I'm not able make link between tickets and add link to help center
Cristian0791
July 25, 2024
Hi Ondrej,
Try to use "Create new issue" not "Clone".
Also when you are creating the automation please ensure that "Linked issue" is selected.
shib saha
July 24, 2024
Hi @Ondrej Holubovsky , In the help Center you can paste the link for its accessibility form portal.
If you are referring to linking a service request from service project to issue in a software project that you can do using the linked issue feature.
Please let me know if the provided solution is feasible for you or you need anything else. Thanks
Ondrej Holubovsky
@shib saha ,
is there any automation for that? I would like to have the link in software project every time is the ticket copied
Rilwan Ahmed
Welcome to the community !!
Where do you want to have link to help center ? on project level (i.e. sidebar) or in each ticket ?
Ondrej Holubovsky
Hi @Rilwan Ahmed ,
I would like to have link in each ticket in software project.
