×I have a requirement to get the activity data inside a jira SD ticket but i am unable to find a rest api using which i can access the data, i need help in finding the rest api through which i can access activity data of a jira sd ticket
You can use the get issue endpoint with expand parameter, this will allow you to expand, changelog.
https://docs.atlassian.com/software/jira/docs/api/REST/9.3.2/#api/2/issue-getIssue
Something like
{jira_baseURL}/rest/api/2/issue/{issueIdOrKey}?expand=changelog
Regards
Hi @Florian Bonniec thanks for the reply.
I checked the change log also but it does not gives me data which comes in the activity tag of a JIRA ticket. Maybe i was unable to phrase my requirement correctly.
When i did the inspect element, the activity tab calls
Request URL:
Hi @Suryansh Tiwari ,
welcome to the Atlassian community!
You can retrieve issue history through the following rest api https://developer.atlassian.com/cloud/jira/platform/rest/v3/api-group-issues/#api-rest-api-3-issue-issueidorkey-changelog-get
Hope this helps,
Fabio
Hi @Fabio Racobaldo _Catworkx_ thanks for the reply.
Request URL:
