problem using JIRA API
MARTOS
July 25, 2023
I've a problem using JIRA API to collect all projects whe have enter in.
When I try whith a navigator, no problem, i got the list, but when I use POSTMAN, I get an empty array.
On EDGE, I use :  https://pouey.atlassian.net/rest/api/latest/project
with postman I use the same url, and in the header I have a Key API and it value.
Someone can help me ?
Evgenii
Hi, @MARTOS
Most common reason is in incorrect credentials. Please, check credentials, that you use
Evgenii
Use basic auth and response from this thread. It works. Checked it a few minutes ago.
https://community.atlassian.com/t5/New-to-Jira-Service-Management/calling-JIRA-REST-API-from-POSTMAN/qaq-p/1073199
Like Marc - Devoteam likes this
