using project automation for issue creation and want to be notified when reporter is as customer
Patrick October 12, 2020
I have created a project automation where I want to send a microsoft team message into a channel when the reporter meets the criteria of beeing a customer. Tried out if reporter is a customer or reporter is in role Service Desk Customers. Both don't work and it is written in the audit log it is written "User Condition: The following issues did not macht the conditions" even when the issue creator is in this specific service desk a registered customer.
I think there is something wrong with our definition of roles or simmilar but didn't find anything like that online.
Please help, thanks
tokcum
October 15, 2020
Dear Patrick,
role members are configured on the project level. You find the roles in the project settings.
Normally all customer accounts are automatically assigned to the role "Service Desk Customer".
Actually I'm testing your configuration with my Jira Service Desk (JSD) instance. This might not be of much use to you because I'm testing with JSD Server. At least it is a second pair of eyes on this issue.
Tobias
tokcum
October 15, 2020
Oh, its even worse. I get a Null Pointer Exception. Nice. I'll have to create a support case for that.
More importantly the customer account was not added to the role "Service Desk Customers". Not sure if I test correctly though. My test user was already in the system and not created with the test issue.
What's your use case in this respect? Are all the customers already known in the system prior to their first issue creation. Or are your customers registered on the fly when they create their first issue?
I also tested your second approach which checks if Reporter is a customer. This worked for me:
Could you please change your if condition to check for a specified user. So really define the user explicitly. I know this is not what you want but sometimes it helps in debugging to simplify the case first.
Tobias
Patrick October 15, 2020
Dear Tobias
thank you for your respond.
My customers are already existing in the system but are not added automaticly to the role Service Desk Customers as I see it. As it is automaticly I don't know how to enforce it.
To define a user explicitly works fine. I changed the rule already. I can almost do anything with the automation rule except recognise when the issue is created by a customer (by role or status).
Thanks a lot
Patrick
tokcum
October 16, 2020
Dear Patrick,
thanks for confirmation. I can't see any other way to proceed despite contacting Atlassian support.
Have a nice weekend.
Tobias
Patrick October 20, 2020
Ok. Thank you for your time.
Patrick
Patrick October 13, 2020
Hi @Manon Soubies-Camy
I am using a project automation rule.
Here is the screenshot of the condition:
image.pngThis is the one with is in role. I also tried Reporter is a customer:
image.pngYes the user created one of the issues that failed is visible from the customers menue:
image.pngBelongs to Service Desk Customer Role? How do I check that? But he is not on any other role as I know so far.
Best regards
Patrick
Manon Soubies-Camy
Hi @Patrick and welcome to Community!
Can you please share a screenshot of the condition you're using? Is this a project automation rule or a global one?
Can you also please check if the user creating the issue:
  • Is visible from the Customers menu (in the left side bar)?
  • Belongs to Service Desk Customers role?
  • Is only a customer or belongs to any other role?
Best,
- Manon
