As an extra option of workaround to the feature request "Include Forms when cloning an issue", this guide is designed to assist users in using the Forms API to automatically duplicate a form between issues.
Copy a form during an issue status transition to a linked issue:
The request method will be POST:
POST https://api.atlassian.com/jira/forms/cloud/{cloudId}/issue/{sourceIssueIdOrKey}/form/copy/{targetIssueIdOrKey}
- Use your Cloud ID (not Org ID). Find it in the URL when accessing your Atlassian admin page, e.g., https://<instance>.atlassian.net/admin/jira-service-desk/portal-only-customers.
- Use the issue ID or Key dynamically with smart values like {{issue.id}} or {{issue.key}}.
- To retrieve the formId, you can use smart values. Begin by accessing the formTemplateID with {{issue.forms}}
. Once you have the formTemplateID, such as "cf638d8b-0498-4b80-8fb1-f547dc769421", use {{issue.forms.cf638d8b-0498-4b80-8fb1-f547dc769421}}
to obtain the formId.
- Add the formId dynamically with:
{{issue.forms.formTemplateID}}
- Specify the targetIssueIdOrKey for the issue you want to copy to. Use the following smart value to get the linked issue's ID:
{{issue.issuelinks.inwardIssue.key}}
- Your automation rule setup should resemble the image below:
Note: By enabling "Delay execution of...", you ensure the rule waits for the web request to complete before proceeding with further actions, which is vital when the request outcome affects subsequent automation steps.
Watch the process in action in the video below:
For Different Projects: The process is similar, with a few additional details:
Watch the cross-project process in the video below:
Bruno Altenhofen
Atlassian Engineer - The guy from Proforma(Jira Forms)
e-Core
Krakow - Poland
1 accepted answer
14 comments
