Copy a Form to the same project and for different projects using Automation and API
As an extra option of workaround to the feature request "Include Forms when cloning an issue", this guide is designed to assist users in using the Forms API to automatically duplicate a form between issues.
Steps to Follow:
  • Set Up an Automation Rule:
    • Create an API token for the web request process. This requires encoding your credentials and API token with base64. For detailed steps, refer to the documentation:
    • Use the REST API feature "Copy forms" in a POST request. Example:
      • Copy a form during an issue status transition to a linked issue:
        The request method will be POST:
        POST https://api.atlassian.com/jira/forms/cloud/{cloudId}/issue/{sourceIssueIdOrKey}/form/copy/{targetIssueIdOrKey}
        - Use your Cloud ID (not Org ID). Find it in the URL when accessing your Atlassian admin page, e.g., https://<instance>.atlassian.net/admin/jira-service-desk/portal-only-customers.
        - Use the issue ID or Key dynamically with smart values like {{issue.id}} or {{issue.key}}.
        - To retrieve the formId, you can use smart values. Begin by accessing the formTemplateID with {{issue.forms}}. Once you have the formTemplateID, such as "cf638d8b-0498-4b80-8fb1-f547dc769421", use {{issue.forms.cf638d8b-0498-4b80-8fb1-f547dc769421}} to obtain the formId.
        - Add the formId dynamically with:
        {{issue.forms.formTemplateID}}
        - Specify the targetIssueIdOrKey for the issue you want to copy to. Use the following smart value to get the linked issue's ID:
        {{issue.issuelinks.inwardIssue.key}}
        - Your automation rule setup should resemble the image below:
Warning Note: By enabling "Delay execution of...", you ensure the rule waits for the web request to complete before proceeding with further actions, which is vital when the request outcome affects subsequent automation steps.
Watch the process in action in the video below:
For Different Projects: The process is similar, with a few additional details:
  1. Ensure your automation rule has a global scope that includes all projects involved (where forms will be copied and sent).
  2. Optional: Implement a filter to identify the linked issue containing the form to be copied, which may vary based on your use case. For example, an IF condition to check if "issues blocked by" was used.
Watch the cross-project process in the video below:
15 comments
Ralph Gerald Varon
Is there a smart value
{{issue.properties."proforma.forms".forms.uuid}}
if multiple forms are attached, it will return multiple uuid as well. how can we get the UUID of a specific attached form?
Like # people like this
Mogens Hald Kristensen
The target issue id  smartvalue should be {{issue.issuelinks.outwardIssue}}
Like Bruno Altenhofen likes this
Bruno Altenhofen
September 20, 2023
Hello @Ralph Gerald Varon
Allow me to share with you this article that explains how to manipulate multiple forms separately:
Thanks!
Mauricio Heberle
September 26, 2023
It works for multiple projects, Ive just tested here. Thanks!
Bruno Altenhofen
September 29, 2023
Hi @Mauricio Heberle
Thanks for the feedback!
Yes!!! I've updated this info in the article!! :D
Cheers!!
Like Mauricio Heberle likes this
Mauricio Heberle
September 29, 2023
@Bruno Altenhofen You're welcome! If this could be added to the component "Add Form", would be great. Also, I noticed that for some automations, it is necessary to refetch issue data before sending the web request.
Jimmy Karlsson December 21, 2023
Is there any way to copy all of the forms from one issue to another? I´m getting this to work the way you have set it up, and when I have several forms the smart value {{issue.properties."proforma.forms".forms.uuid}} returns all the id's as this;
5b44c132-802b-48b0-a5cb-60b864360d37, 226dac84-d5d5-4355-8080-1f4cc550148c, 2d4b93e8-112a-4faf-98f8-abe9c11ee329
This does not work in the "Custom data" field tho, I´m getting this error:
{"errors":[{"status":400,"code":"BAD_REQUEST","title":"There was an issue with your request","detail":"1 error found in JSON: (1) /ids(0) should be a UUID"}]}
Nia Yanes Barreto
March 29, 2024
Would this solution only work with ProForma forms? If so, is there a workaround for Jira built-in forms?
Mauricio Heberle
March 29, 2024
@Nia Yanes Barreto Its for forms created in "Forms" module within Jira Service Management projects.
Lukasz
April 12, 2024
Hello @Bruno Altenhofen
Is it possible to use this workaround to copy a form from one project to another project when both of them are Team-managed (next-gen) projects? In that case, are there any special steps to follow?
Thanks for your response!
Fye
May 8, 2024
The POST method endpoint in the workaround contains a duplicate "jira" string. It should only be one as documented in the GET Forms REST API doco e.g.:
@Bruno Altenhofen Can you correct the endpoint URL, please?
Bruno Altenhofen
May 9, 2024
Hey guys!
@Lukasz - Yes, you can certainly utilize this approach in a Team-managed (next-gen) project. Additionally, you have the flexibility to copy forms between the Team and Company-managed projects as well.
@Fye - Updated! Thanks!! :D
Maciej Warowny
February 25, 2025
Hello team!
@Bruno Altenhofen the proper Custom data body should look like this:
"UUID": [
"{{issue.forms.<form_id>}}"
We need to use UUID instead ids in the body.
Last thing, if you have problems getting form id you can just log this value using Log action with {{issue.forms}} in Automation rule on the issue having proper form attached :)
Best,
M.
Bruno Altenhofen
April 21, 2025
Hello @Maciej Warowny
Thank you for sharing that information with us! :)
I've gone ahead and updated the article regarding the {{issue.forms}} property to include this detail.
Regarding the use of UUIDs, you can indeed use both UUIDs and IDs in the Custom data body. I opted for "ids" in the documentation because the terminology in the form properties was updated from "UUID" to "id" (formTemplateID). You can find more details about this in the article here:
Best regards,
Josh Drake April 24, 2025
Hi Bruno,
I am running into an issue in which I believe OAuth 2.0 to be the cause. How did you configure the API app for this web request? (this is my first time utilizing either feature)
Thanks in advance,
