Delete all worklogs from an issue using Jira Automation with REST API
36 comments
Alex Ziegltrum
Found out, when using the "validate" function in an automation rule, you can't use a smart value for your Authentication. With this, the validation works.
Now, I am focusing on identifying a certain worklog, which in my case is the last one created / updated as the trigger for my autom. rule.
Susanne is helping me on in this thread Time tracking to slack (atlassian.com)
Dave Zuzak February 27, 2024
I hate to bring an old thread back, but hoping my ask helps someone else. I'm getting the 400 error depicted.  Thoughts?
Like Vikrant Yadav likes this
Tara
March 24, 2024
@Alex Koxaras _Relational_ Thank you for your work to document this article and share it with the community.
To extend on existing suggestions from https://community.atlassian.com/t5/Jira-Software-articles/Delete-all-Tempo-worklogs-from-an-issue-using-Jira-Automation/bc-p/2647017#M12703 to only fetch and delete worklogs that were created before a specific period (e.g. start of the month), the following syntax can be used:
?maxResults=5000&startedBefore={{#now}}func=minusMonths(1).endOfMonth, format="toMillis"{{/}}
Bill Sheboy
March 25, 2024
Hi @Tara __
Thanks for your ideas extending this for Tempo worklogs.  Does that URL parameter for startedBefore encode to a UNIX Timestamp (i.e., milliseconds after 1 Jan 1970)?
For those doing this filtering with the built-in Jira REST API rather than the Tempo one, the function takes a UNIX Timestamp in milliseconds.  https://developer.atlassian.com/cloud/jira/platform/rest/v3/api-group-issue-worklogs/#api-rest-api-3-issue-issueidorkey-worklog-get
And so to use the startedAfter or startedBefore parameters for a different field than {{now}}, the math difference must be performed relative to the UNIX Epoch.  To accomplish this, you may save the time value for the UNIX Epoch in a variable and then perform the difference.
  • create variable:
    • name: varUnixEpoch
    • smart value: {{now.withYear(1970).withDayOfYear(1).toDateTimeAtStartOfDay}}
  • get your parameter, for example relative to {{issue.created}} convert the values and diff()
    • {{varUnixEpoch.toDate.diff(issue.created).millis}}
Like Tara likes this
Tara
March 25, 2024
@Bill Sheboy Thanks for the suggestion! I think that's another great example to base the timestamp off the issue's created date and the more options people have to work with, the better chances it has of serving all the various use cases.
Though my inspiration came from the Tempo worklog article, this timestamp was applied to Jira worklogs and the full API I used was:
https://{SITENAME}.atlassian.net/rest/api/3/issue/{{issue.id}}/worklog?maxResults=5000&startedBefore={{#now}}func=minusMonths(1).endOfMonth, format="toMillis"{{/}}
{#now} with a formatting of "toMillis" should give a timestamp in milliseconds relative to UNIX Epoch. minusMonths(1) and .endOfMonth are other auxillary functions to align to a specific window. Hope this can help anyone looking to enhance automation to delete Jira worklogs.
Like Bill Sheboy likes this
Bill Sheboy
March 26, 2024
Thanks, @Tara __
I tried that for a date / time field and it produced the same result as you see for {{now}}, so the variable and diff do not appear to be needed (unless the date calculation scenario is more complicated).  Do you have a link to the Tempo worklog article as I did not see that example on the REST API doc page for Tempo?
I wish features like this were better documented for rule handling :^)
Tara
March 27, 2024
@Bill Sheboy This is the article for cleaning up Tempo worklogs using their APIs https://community.atlassian.com/t5/Jira-Software-articles/Delete-all-Tempo-worklogs-from-an-issue-using-Jira-Automation/bc-p/2647017#M12703 . The linked comment also shows how you can provide smart values to hone in on a specific time range:
https://api.tempo.io/4/worklogs/issue/{{issue.id}}?from=2019-12-01&to={{now.minusMonths(1).endOfMonth.jiraDate.urlEncode}}
mummareddy supriya
@Alex Ziegltrum I have to delete the worklog after cloning the Epic issues using automation rules in jira
I Applied this  Automation Rule ,In place of webhook url i used https://your-domain.atlassian.net/rest/api/3/issue/projectkey/worklogid. in Header i provided useremail:personal token .but  its not working  and i'm facing below error when i gone through the logs ,may i know the reason please . Thanks in advance error.PNGheader.PNG
Why header is not allowing Delete option ,If any one have idea on this issue please let me know please .thanks in advance
Alex Ziegltrum
Hi @mummareddy supriyaas it seems to me, you might need to check the endpoint, you want to use. I am referring to https://developer.atlassian.com/cloud/jira/platform/rest/v3/api-group-issue-worklogs/#api-rest-api-3-issue-issueidorkey-worklog-id-delete
mummareddy supriya
@Alex Ziegltrum Followed same url as you provided ,Delete
/rest/api/3/issue/{issueIdOrKey}/worklog/{id} this is the endpoint i'm using .But still facing above 401 error .please guide me here if anyone knows the issue .thankshttps://community.atlassian.com/t5/Jira-articles/Delete-all-worklogs-from-an-issue-using-Jira-Automation-with/bc-p/2728348#M14829
