  • Community
  • Q&A
  • Jira
  • Questions
  • Automation Rule to add the attachment using Automation for Jira which are newly added to comment
SaiSatya {Appfire} June 6, 2024
Hi Team,
I want an automation rule to add attachments as comments if we add any image to the comment, excluding already existing images.
Say, suppose I have four attachments in the ticket already, and I have uploaded a new image in a comment. I want only the newly added image comments again by excluding the older four attachments.
I'm using the below automation, which is adding existing attachments as well.
{{#attachment}}
!{{filename}}!
Duc Thang TRAN
June 6, 2024
Hello @SaiSatya {Appfire}
If I understand correctly, your need is:
When a new attachment is added, you are looking for a way to delete all old attachments except the new one.
Is this correct? If so, I can try to help you find a solution.
{{attachment.last.filename}}
SaiSatya {Appfire} June 7, 2024
Hi @Duc Thang TRAN
My actual use case is when I add a new attachment added to a comment, I want the same attachment to be commented once again by Automation for Jira. For me If I add one attachment in comment Automation for Jira it's adding older attachments as well.
Duc Thang TRAN
June 10, 2024
If you want the automation comment the last attachement, can you try this smat value ?
!{{attachment.last.filename}}|thumbnail!
You can try this one if in your last comment, is has only a attachement and now texte
{{issue.comments.last.body}}
Hope this can help your need :)
Duc Thang TRAN
June 10, 2024
* You can try this one if in your last comment, is has only a attachement and no  texte
