Hi Community,
I'm creating a manual trigger automation that creates a series of tickets for my devs. The trigger starts in a Service Desk ticket and when Run (Ran?) it creates tasks in 4 Software Projects.
The issue is that the string custom field smart values are not populating. All the booleans or multi-select / radio button type custom fields are passing just fine, but anything with a string / free text is not coming over.
I've tried the following different smart strings without success
{{issue.customfield_11506.value}}
{{triggerissue.customfield_11506.value}}
{{customfield_11506.value}}
{{Client Name.value}}
{{Client Name.string}}
{{customfield_11506.string}}
edit: in JIRA, just to test, I've added "Client Name" custom field to all the relevant screen / screen schemes.
Hi Rosa,
Almost there.
String/text values don't have any attributes - they are just the string. e.g. the following will work for you:
{{issue.Client Name}}
Hope that helps.
Nick [Automation for Jira]
@Nick Menere thank you!! (That was my next guess 🤣🙄)
I tested it and sure enough... I appreciate the response and solution.
