Hi all,
Any help with the following would be appreciated. I want to insert a label whenever a custom field (supplier name) changes from a specific supplier to anything else. I have got:
When field value changes for (supplier) ...
If supplier equals X ...
Then Edit Issue Fields (Labels)
However, this only inserts the label when the supplier name changes TO the supplier in question. I need a way of triggering the label insertion when supplier name changes FROM this supplier to someone else.
Thanks.
You can access the previous supplier name using the Smart Value {{fieldChange.from}}, that you can use in a JQL condition for instance.
Let me know if it helped or not,
Guilhem
Thanks @Guilhem Dupuy
I can insert a condition 'If issues matches JQL' but I'm failing to format the JQL correctly. The custom field is called Supplier. So I'm thinking it should be {{SupplierChange.fromSupplierName}}. Any further help much appreciated. Thanks.
The smart value which returns the changed value is {{fieldChange.from}} independently of the name of your field.
However, this smart values returns the raw value, if you want it to display a specific type like a String for instance you should rather use {{fieldChange.from}}
