Hi all,
I created a legacy automation:
But I didnt receive any alert if I change the priority from low, which is our current default, to highest.
Anything else I have to check, to get this alert running?
Hi @Susann Petzold ,
Your rule says "Issue created". So automation will only work when you create a ticket with Highest/high.
Add one more automation with "Issue updated". This should solve your problem
Why Legacy?
You can check, whether the user has access to the issue when sending the notification.
Better yet - Create Automation rule with new Automation for Jira feature!!
