Wanting to setup a JSM automation rule that runs on a schedule to check the Status field of an asset, if Status = Awaiting Decommission then email assigned user of asset.
Looking to get help please on how to do the "if status = Awaiting Decommission"
plus
How to get Email field from assigned user of the asset.
Hi @Steve C
It all depends on how you have setup your project/solution. Jira automation has the capability of checking object's attributes:
You may want to use smart values as well: https://support.atlassian.com/cloud-automation/docs/jira-smart-values-insight/
Appreciate the reply, simply have a JSM project and a schema for Assets.
My challenge is there is zero native integration between JSM and Assets without building it yourself. Assets has been bolted into JSM without any smarts.
Hi Steve,
This article should help you get started with it:
@Bhanu this link is for the DC version of assets, which utilizes a built in automation engine. On cloud Assets use the project automation.
