×Hi everyone,
Unfortunately, Automation doesn't support remote links (links between instances) or copying between instances at the moment. The issue for remote link is being tracked at: https://codebarrel.atlassian.net/browse/AUT-176
Hi @Patricia Vale - When you're working cross-project, you need to change the project scope in the rules detail section. You want to either change to multiple project and manually select which projects are in scope or set to all projects.
Hi @Mark Segall ,
Thank you for your answer.
I experimented with the "rule details" restricted only to the projects as you spoke. But the same error still exists.
Does your rule Actor have the same permissions across each project?
