I can't seem to find Atlassian documentation for this nor any previous questions in the forum here.
If I click on Requests (top RH corner) I have two choices: My Requests and All Requests.
All Requests doesn't appear to do what I would have thought. All I see are the request I made.
Similarly, there is a drop down on the Requests page that includes: Created by Me, Created by Anyone, Where I am a participant. Again, i would assume the Created by Anyone would show me all requests created but I get nothing. I also get nothing w/ Where I am a participant but that may be that I'm not a participant on any. I will test that out.
I suspect that this has to be configured somewhere but haven't found it yet.
That is related to the new organization feature we launched. Please have a read at the blog post. In short you could also see requests raised by others in the same organization.
Gerry, thanks for the answer. I working on it now. If i'm using this correctly, adding customers to an organization seems very tedious/onerous. It appears I must enter each person's username/email. I currently have 200+ employees in the company. This will take awhile.
Maybe there is a better way?
scratch that inquiry. I was able to export all users, massage in excel, copy all users and then paste into the add customers to org box. Maybe a "bulk change" option similar to what is done for JIRA issues would be useful feature add.
So it appears that this feature (by default) sends out notifications to everyone in the organization when a ticket is created (and possibly commented on). That certainly isn't desirable for me. I simply want to allow users to see them via the portal if the so desire. Scrambling to see if I can address this unwanted behavior before i disable.
Gerry,
I ended up disabling. I'm hoping there is a way to disable notifications. Maybe that is the primary purpose of the feature. However, I would strongly suggest that organizations should be treated like groups and if you want the "opt in" notification to go to the organization when an issue is created then you should require adding the organization to the Notifications/Create. Maybe the ability to disable is already there? Please advise.
Jack,
You can go to Project Settings > Customer notifications and disable the Organization added email rule.
Gerry,
excellent thank you. This was not initially obvious unfortunately. Unsure why "Customer Notifications" are separate from Notifications page.
Gerry,
is there a way to default tickets to private so that I can keep the notification active s if someone makes the conscious decision to add the organization, they can notify all members of their org regarding the ticket, but otherwise it's defaulted to "private" so that the org wouldn't be defaultly added for non-urgent items?
Since the default can't be made to be private; I'd like the hide the entire drop-down option.
Hi everyone. I was researching the same issue, and came across this conversation as well as a reported issue: JSDCLOUD-4382. If you're frustrated by this too, please head over and vote for it.
