How can I get existing values for a custom field in ScriptRunner?
john history April 3, 2024
I have a Jira service desk set up, and I want to validate users' entries in the service desk fields. For example, I have text field and I want the users to only be allowed to enter unique values. So if user A submits a request with "My text" for the field then I want no other users to be able to successfully submit a request with "My text" in that field.
I currently have a Custom Script Validator to run code logic on user entries, but I cannot figure out how to retrieve the values previously entered by other users. If I could do that then I would be able to check 'is the value of this field in this list of existing values?' and deny the creation of the issue accordingly.
Is there a way to do this, or if not, what might my other options be for getting the desired behavior?
PD Sheehan
April 26, 2024
I would simply execute a JQL search in your validator. Since you field is a text field, you must use a match operator (~). Then take all the matching issues and further refine them with an exact comparison.
Here is a sample script (custom scriped validator):
import com.adaptavist.hapi.jira.issues.Issues
import com.opensymphony.workflow.InvalidInputException
def cfm =ComponentAccessor.customFieldManager
def uniqueFieldName = 'unique field name'
def uniqueField = cfm.getCustomFieldObjectsByName(uniqueFieldName)[0]
def currentValue = issue.getCustomerFieldValue(uniqueField)
def jql = """project=$issue.projectObject.key and cf[$uniqueField.idAsLong] ~ "$currentValue" """
def matchingIssues = Issues.search(jql).collect() as List<Issue>
def exactMatchIssues = matchingIssues.findAll { it.getCustomFieldValue(uniqueField) == currentValue }
if (exactMatchIssues) {
throw new InvalidInputException(uniqueField.hiddenFieldId, "${exactMatchIssues*.key} already contains '$currentValue' in '$uniqueField.name'. This field must be unique accross all issues.")
Gikku
@john history Not a straight forward suggestion, but the below might work.
  • Create a select list and make it hidden from the screens
  • Whenever an issue is created with a value for the text field, add that value as an option to the select list
  • Use the options currently available on the select list field to validate if the value entered on the text field is unique or not
john history April 4, 2024
I like that idea. Its very simplistic. I will give it a try today.
The issue with this solution is that I would have to track down all existing values to manually enter as hidden options.
I did more investigation into reading from the database and it looks like the customfield table does not contain all the custom fields. I don't know where these missing custom fields are being stored. They show up in the UI but not in the database (at least in that table).
Gikku
You are looking the custom field values, right?
You can query the customfieldvalue table with filter customfield = <ID>, which you can find from the UI.
