if you are in cloud, just re-invite them again from customers->invite customer, an invitation email will be sent to them.
That is the issue....there is no "reinvite" option since they were never invited in the first place. They came in thru an import. Unless I'm missing the reinvite somewhere.
The only option the User Management screen provides is "deactivate". So they are activate w/o any password. The only option I see at the moment is to go thru each of these users, set a temp password, have them log in and then change their password.
you can do it from customers page within your service desk project, click invite customers and put in their user name or email address and click add, you customer will then get an invitation email which they can use to set their password.
image2016-9-13 9:13:33.png
got it. yes I think that will work for me as I can export all users into excel, concatenate the emails w/ commas separating them. I assume the comma-separated is the correct format.
Thanks!
you can separate the email/user names with either comma or space, both should work.
I thought I would provide an update. This hasn't really worked as I had hoped. Since the user already exists in the system (never logged in) when they receive the "invite" email and attempt to login & create a password they receive a 'user already exists' notification. At this point I think I'm going to have to provide all users w/ an initial password and the portal link via an email. From there they can log in and change their password. Very cumbersome.
