How to get JIRA projects with pagination through rest api?
Ashish Bijlwan May 16, 2018
We have more than 50 projects in jira and we want only first 10 projects in our app and later 10 more.how can we achieve this through jira rest api?
Regards
Ashish
Kirubel Tesfaye
May 17, 2018
Hi @Ashish Bijlwan,
If you refer to documentation for the Jira rest api you used, you will see that it return list of all of project visible for the currently logged in user, i.e. all the projects the user has either ‘Browse projects’ or ‘Administer projects’ permission.
So the solution I have found is that either to use a user that has access to only the 10 project or use the recent property.
Ashish Bijlwan May 17, 2018
Hi @Kirubel Tesfaye,
So there is  no way of pagination while getting project list?
Kirubel Tesfaye
May 17, 2018
hello again @Ashish Bijlwan,
The documentation vaguely state that pagination is enforced for methods that could return a large collection of items without clearly defining how much large is.  I think they assumed that list of projects couldn't be large and didn't enforce pagination on this api.
So instead use the recent query parameter, which if set returns Only projects recently accessed by the current user. If no user is logged in, recently accessed projects will be returned based on current HTTP session. Maximum count is limited to the specified number, but no more than 20.
Hope this Helps!
Screen Shot 2018-05-17 at 4.03.59 PM.pngIf that is the case then how they are achieving pagination in  their JIRA website?
Kirubel Tesfaye
May 17, 2018
Hello again @Ashish Bijlwan,
This is different kind of pagination. This kind of pagination is created using HTML & CSS
The pagination we are talking about is different.
Ok..means you want to say that their also they are getting all project at a time but by using html/css/javascript ,they are showing in form of pagination
Kirubel Tesfaye
May 17, 2018
Yes
OK..Thanks @Kirubel Tesfaye
Guntur Nitin Shashank
July 15, 2021
Try this,
<org_url>/rest/api/latest/search?project=<project_key>&startAt=0&maxResults=50
Dhruv Dixit February 25, 2019
For the recently accessed 10 projects use:
<org URL>/rest/api/2/project?recent=10&maxResults=10
Aniruddha Gayake October 21, 2021
Rambabu Patina _Appfire_
May 16, 2018
You may have a look at pagination section in https://developer.atlassian.com/server/jira/platform/rest-apis/
Clients can use the startAt, maxResults,andtotal parameters to retrieve the desired number of results.
this is the  rest api for getting the project list :-<org URL>/rest/api/2/project
i am also passing startAt and maxResults parms but not getting limited data.
<org URL>/rest/api/2/project?startAt=0&maxResults=10
May 17, 2018
Try add the 'total' parameter something like <org URL>/rest/api/2/project?startAt=0&maxResults=10&total=100
ok..let me check
not working...still getting all projects list
Like Esther de Mattos Silva likes this
于志鹏
December 5, 2018
yes I have try this  and get all projects list I think I need to use recent instead startAt
Like zqh likes this
