When I use automation to create sub task by user role "user has access site", It's not work, the automate rule can't create sub task as I expect.
I got error as picture below
How to solve the issue? Thx in advance.
Could be a few problems, first thing to check is that the project(s) you're writing the rule for
can use sub-tasks - so you'll want to check the issue types available for the project.
The other problem could be that "user has access to site" isn't the (only) permission used to create issues. You do need that one, but you also need this Permission for whatever role you're using..
can you check to make sure the Actor (in rule details) is set to Automation for Jira?
it's also possible I misunderstand exactly how you're building this rule. If that is the case, please take a picture of the actual rule steps so we can help more.
Good luck!
