Is it possible to use nested Smart Values?
Sean Dooley
July 3, 2020
I can't seem to find a way to use a variable inside a smart value. For example:
{{ now.withMinute( {{originalMinutes}} ) }}
...where {{originalMinutes}} is declared earlier in the automation as a math function:
{{#=}} {{issue.customfield_10030.toStartOfDay.diff(issue.customfield_10030).minutes}} - ({{originalHours}} * 60) {{/}}
I'm trying to update a datetime value to a new date, while retaining the time. So far I have all the pieces, but when I go to put them together, they require nesting of some sort, which appears unsupported.
One way around this would be if I could pull the hour, minute, and second attributes directly from the original datetime, but that also appears unsupported (or at least poorly documented).
4 votes
Ignas Selvestravičius
Atlassian shared with me the solution.
So it is possible to do nesting with variables. Here is how:
  1. Create a variable varTemp to hold the value "originalMinutes"
  2. Then use the variable like this:
    {{now.withMinute(varTemp)}}
    Note that you don't need the braces inside the brackets.
Below is my automation which might give you a better understanding. My case: add business days to get Due date to create issues every month with new Due dates.
Knust_ Johannes
lovly! Thanks for sharing. This also works in complex regex like:
{{lookupIssues.summary.match("^(?:CR|RW)HighestCycleNumber-(\\d{3})").asNumber.max}}
Like # people like this
Eric Pratt
March 10, 2025
@Knust_ Johannes how do you get this to work with regex? Can you provide an example?
I tried creating a variable with the name regex and the value of:
"entryId=[^&]+&", "entryId={{userInputs.id}}&"
and the try to call it later like so:
{{webResponse.body.body.atlas_doc_format.value.replaceAll(regex).jsonEncode}}
But it just returns empty. I verified it works if I hard code the regex into the second call.
Knust_ Johannes
hi @Eric Pratt _Jira Admin_
it seems jira changed something; nevertheless here is my scenario and solution to it.
my requirement was a jira issue with title t should be able to automate with a change request or reword and marked in a new ticket t+1 with CR02-000 (first digits) or rework RW01-001 (last three digits) increase +1
therefore from t to t+1 its easy you know its the second ticket so either its CR +1 = 2 or its RW therefore 01 stays and the sum of 000 + 1 = 001.
The magic starts with reading from ticket t how many linked tickets t+x exists; read the last and calculate based on the logic + 1.
I found out that I can do things like this:
(easy)
var: HighestCycleNumber =  {{lookupIssues.summary.match("^(?:CR|RW)(\\d+)-").asNumber.max}}
(advanced - a two step process!)
var: TempRWCycleNumber = {{lookupIssues.summary.match("^(?:CR|RW)(\\d{2}-\\d{3})").replace("-", "").asNumber.max}}
var: RWCycleNumber = {{TempRWCycleNumber.right(3)}}
and than some if else explosion (yes I used pen and paper to get my scenarios)
When creating than the new ticket the title is in this first example:
RW0{{HighestCycleNumber}}-00{{RWCycleNumber.asNumber.plus(1)}} : {{triggerIssue.summary}}
Why so complex?
Easy, when using regex Jira does not allow to keep leading 0's...
Therefore I had to identify the amount of leading 0's and made it work.
hope that helps; it took me a while and AI could not figure that out either :P
Iago Ubeira Martínez
May 5, 2025
Hi!
I just figured it out — you need to wrap the variable in parentheses when using it.
For example:
Let's say you sometimes need to access issue.fields.customfield_1234.value and other times customfield_4321.value.
  1. First, define a variable like this:
    {{var}} = {{issue.fields.id}}
    This will return either customfield_1234 or customfield_4321.
  2. Then use it like this:
    {{issue.fields.get((var)).value}}
This way, Automation will correctly read the value from the dynamic field — whether it's customfield_1234 or customfield_4321.
Hope this helps!
Darryl Lee
Don't you wish we could upvote Automation feature requests:
Possibility to nest smart values in Automation:
https://codebarrel.atlassian.net/browse/AUT-2086
John Funk
Hey Sean - Welcome to the Atlassian Community!
Take a look at this previous post:
https://community.atlassian.com/t5/Jira-Core-questions/Is-there-a-way-to-concatenate-or-nest-smart-values/qaq-p/1374187
FREE
