Is there a way to automatically assign an issue to specific fields (like priority, security levels, etc) when it's assigned a specific field? For example, when an issue is set to a label (e.g. TechnicalRequest), it would be set to priority Low and security level to a specific project role?
you could probably do the trick by setting all those values (label and default values) as post-functions of a transition.
Another way that could be worth testing would be the use of Automation plugin (tutorial/blog post : automation-update-jira-issues-automatically )
He cannot use post functions since he needs this during a normal edit as well. And he cant go for such plugins since he is working in a cloud instance.
Hello Mahesh,
Either an automation (status change) or while editing the issue. I have checked the automation and it seems I have somehow limited options. I am trying to find a way if there is already one readily available. Thanks!
Herson
This requirement should work during a status change or in normal edit conditions as well?
