JETI - Notifications not sent on create issue
Gregory Demotchkine
Jira version: 6.0.8
Jeti version : 5.3.2.1
I have configured JETI with a creat issue template and and a notification scheme that should sent a notification with this template when an issue has been created. I've tested the notification using Test and it works, but it's not sending anything on issue creation, unless I activate the the standard jira notificaitons in the project, but that ends up sending twice the notification, once using JETI and another using the standard jira notifications
Greg Hoggarth
Really? That seems very bizarre. JETI has this whole system of events and contexts, very similar to the Notification scheme in Jira. But then to actually get it to send emails, you have to manually edit every single transition to have a post function to send an email?
Jira's standard notification is so much better.
Michael Simon
December 30, 2013
Inside your JETI notifications you created an event. Now from your workflow trigger this even in the post functions. Function type "Email This Issue". It will list the events you created. Works like a charm. Make sure your default notification scheme doesn't have a trigger for this event type.
