I ran into an issue with my automation and am hoping someone could help.
Goal: Create a service desk issue from releases via automation.
Issue: There are two required fields in service desk where I am unable to copy the information from release.
Example:
There are two required field in service desk, "Summary" and "Engineer Lead" (custom field)
I need Summary to be copied from "Release" name.
I need "Engineer Lead" to copy from either the Driver or Contributor.
Automation:
Trigger: Version Release
Then: Create issue
I can't find anywhere that this is possible, want to double check with the community, if not, are there any workaround?
Thanks much!
Garret
Seems like I can use {{version.name}} to get the release number and {{initiator.displayName}} to get the person that triggered the release.
