Jira automation rule for two custom single select fields Cause (Level 1) and Cause (Level 2)
BiruteK January 15, 2025
I have created Custom field Cause (Level 1) with dropdown options: People, Process, External, Systems and Infrastructure
Another Custom Field Cause (Level 2) with all the subcategories list)
How to add automation Rule For dependent fields, if Cause (Level 1) = People, then Cause (Level 2) =
Poor behaviour
Inadequate management control and supervision of staff
Inadequate training and competence
Inappropriate remuneration model
Human error
Key person/knowledge dependency
Insufficient or unavailable resources
Third party
if Cause (Level 1) = Process, then Cause (Level 2) =
Inadequate policies or procedure manuals
Inadequate design of process
Inadequate design of product
Inadequate monitoring, reporting and control management
Change execution failure
Mismanagement of records
Poor data quality or process
Model error or misapplication
Incorrect documentation (e.g. customer, product, employee)
Legislative or regulatory
If Cause (Level 1) = Systems and Infrastructure then Cause (Level 2) =
Inadequate hardware, software or network capabilities
Hardware, software or network failure
Hardware, software or network malfunction Inadequate hardware, software or network maintenance
Inadequate external hardware, software or network support
Non-IT infrastructure (e.g. utilities) failure
Non-IT infrastructure (e.g. utilities) outage Inadequate access management
Inadequate physical security
if Cause (Level 1) = External, then Cause (Level 2) =
Legislative or regulatory change
Market infrastructure change
Natural disasters
Man-made disasters (non-malicious)
Criminal/terrorist activities
Social engineering and identity theft
Civil and political activities
Failure of third party to deliver contracted service level
Cause (Level 1)
Dick
Hi @BiruteK Welcome to the Atlassian Community
I'm sorry to say that by restricting yourself to two custom fields, you're setting yourself up for database disaster. As @Karan Sachdev mentions, use cascading select list. This is the only way that reports derived from it will be interpretable in only one way.
Salih Tuç
January 15, 2025
You can use if/else block on the automation.
On the first if condition, you can select two fields' combinations and you can add else-if for others. For more details on the condition, you can check the related documentation.
BiruteK January 16, 2025
Are you Able to provide more details for this rule, I started as instructed by you, but not sure how to continue?
Karan Sachdev
January 15, 2025
Hey Birutek,
Welcome to Community!
Do you want to display only the specified values for level 2 based on the selection in level 1? For example, if the users select People in level 1, they should only see the below values for Level 2:
Poor behaviour, Inadequate management control and supervision of staff, Inadequate training and competence, Inappropriate remuneration model, Human error, Key person/knowledge dependency, Insufficient or unavailable resources, Third party.
If so, you may consider creating a custom field of cascaded select list type. Your Level 1 options will be the parent values, and level 2 values will be the child values against each parent value.
Here's a KB article from Jira data center but it's valid for cloud as well: https://confluence.atlassian.com/jirakb/jira-data-center-how-to-create-dependent-cascading-lists-in-jira-1142426572.html
Karan Sachdev
Yes this is correct, however Cascading is not an option for me , because I need to have two separate fields in the issue for reporting purposes
