Put custom field values in JIRA Automation "Send Email" action?
Evan Winter June 27, 2017
Edit: I read this thread but none of these solutions worked for me.
I've created a rule in Automation that sends a unique email notification if an Issue is created of a certain Issue Type.
I'd like to inject several custom field values into that email.
Is that still possible? I know some things have changed with the plug-in so I don't know what information I've seen online is still accurate. I can't find an "Allow variable expansion" option, as I've seen many say you must turn on.
My understanding is that the older Automation plug-in used Velocity templates, and the newer one from CodeBarrel uses Mustache. I wasn't sure which plug-in I had (it's the one that came with JIRA Server as of about six months ago), so I tried both syntaxes.
send-email-automation.PNGNeither of those worked. The email I recieved just contained those statements as they are shown above.
Any help would be greatly appreciated! Thanks in advance
Rakesh Govardhan September 3, 2018
Even i m facing the same problem... any help ?
I read this blog post and now understand much better. I'm using JIRA Automation, not Automation for JIRA.
