Hello. Our team currently has an automation rule set to create issues quarterly (that part is working as expected). We are attempting to discover a way (if at all possible) to have the issue summary state actual quarter months i.e. "Jan-Mar/2025" The current smart value being use is {{now.format("MMMM/yyyy")}} which shows, for example, as “Jan/2025”
Any insight from the community would be most helpful. Thank you.
Hello @Matt S_
You could do this by concatenating values.
{{now.format("MMMM")}}-{{now.plusMonths(2).format("MMMM")}}/{{now.format("yyyy")}}
Thank you all for your warm welcome and quick turn regarding my inquiry. The solution @Trudy Claspill provided worked! I really appreciate it!
Hi Matt - Welcome to the Atlassian Community!
Can you share a screen shot of the context in the rule as it is being used?
