Automation for automatically set organization field
nida ergenç May 22, 2025
Hi community,
I need your guidance about automation,
We want to separate the organization as sales and finance. However, since all users use the same domain, we cannot automatically add them to the relevant organization using the domain.
That’s why i have tried to create automation rule based on Main Section.
For instance; If main section value is finance (sales), organization field shoud be Finance.
finance organization ID:3
"fields": {
"customfield_10002": [
"id": "3"
Note:
  • Jira Cloud
  • Standart Plan
  • Company-Managed Project
4 votes
Manon Soubies-Camy
Hi @nida ergenç,
Is there a specific reason why you're using the organization id?
If not, you can simply type the organization name directly when setting the field in the automation action:
Hope this helps!
- Manon
Manon Soubies-Camy
Also, I just noticed you’re using a branch in your automation rule. For your use case, using a condition instead would be a better fit. Here’s an example of how you can configure it:
Like nida ergenç likes this
Thanks a lot @Manon Soubies-Camy , it works! i have tried to add same user into organization that's why i used organization ID.
Do you have any suggestions about it? If main section is Finance(sales) organization field shoud be Finance and add to same user into Finance organization.
Like Manon Soubies-Camy likes this
Manon Soubies-Camy
Sure, you can do this with another condition and action:
  • If main section is Finance
  • Set Organization A
    • If customer is not already in Organization A
    • Then add customer to Organization A
  • Else if main section is Sales
  • Set Organization B
    • If customer is not already in Organization B
    • Then add customer to Organization B
It would look like this:
  • Condition: If customer is not already in Organization
  • Action: Then add customer to Organization
This will work even if the reporter already exists as a customer, it will simply add them to the organization.
Like # people like this
Dear @Manon Soubies-Camy ,
I've been struggling in that automation for while,and dont know how to thank you enough!  :)
Manon Soubies-Camy
Glad it helped! :)
