I am using Jira Service Management, in particular the Support ticket system.
I want to add an automation where, every time an issue is created, depending on the Request Type of that issue, system automatically assigns a specific Label.
Automation doesn't work and I don't understand why.
I also added a Re-fetch issue data after the trigger, based on some old discussions here in the Community space, but it didn't solve anything.
Thank you for your help,
Enrico
HI @[deleted]
Does the automation failed or works. What the rule audit say ?
Regards
It seems the Re-fetch is the only thing that is working fine:
The problem seems to be in the Request type, but I don't understand what is wrong.
I have created several Request types and I want that if the created issues falls into these 2, the trigger applies:
Do you have any ideas?
Thank you for your help!
Thank you again for your help.
Unfortunately, that's not my case: we only use a single language in our Jira. Anyway, I tried to follow the workaround, but it doesn't work.
The mistery goes on...
@Florian Bonniec I finally found the problem! I don't know why, but Jira doesn't recognize the "Request types" at all. In fact, I used "Issue type" instead of "Request type" and now it works.
Many thanks for your help.
Enrico
