When I create a new JSD project using shared config from existing JSD project, I get the following error when trying to add or edit my automation rules:-
"Choose a different user so your automation rules will run as intended"
and
"The selected user has been deleted"
When I try to select a new users, I get the following error:-
"No options"
Steps:-
I get the same errors if I try to create new rules in the second project, but they do seem to run as the same user in the original project
Is this a known defect?
Paul.
The Automation App User is the one which needs permission in your projects to run the automation
This is done by adding the group Im mentioned before.
Although you used the shared permission scheme, did you verify the group portion I have mentioned?
Also, if the user you are trying to select a user that does not have an role in your project it will not work.
People in the roles are not shared btw projects, you need to add the user in the role.
Considering that is JSD project, this user, to perform actions need to be an project agent, otherwise he/her will not be able to trigger the rules.
The user is assigned to the following in this 'broken' project:-
And also is:-
I've also added another user to the project and they have:-
and
But still when selecting the JSD automation config i get "Choose a different user so your automation rules will run as intended" and there are no options in the drop down....
Creating a new project from scratch works is expected - it appears to be only an issue with creating a project with shared configuration (but the project that the config is share the configuration with is working ok.
Maybe the answer is to create a new project and manual attach the share config?
Per the snapshot you are using the legacy project automation for JSD.
Did you try typing the user name instead of waiting for option, as i mentioned earlier?
This is the problem, some bug, and I have the same problem here in my instance
No user showing when i click in the drop down menu
Started typing:
I know this is silly, but you should try.
That 'silly' answer was the correct one!
Sorry for not trying that!
Thanks for all your help!!!
Hi @Paul Brown
You need to check if your permission scheme has the Role
This will enable the automation user to be on the project.
More info here
https://confluence.atlassian.com/servicedeskcloud/blog/2017/02/add-on-permissions-update
Hi Patricia,
I don't think this is the answer as the permission scheme is shared by both projects, and this first project doesn't give this error, but the second project does.
Thanks Paul.
I had the same problem. It was the permissions, but found another "tip"
Try typing the user,
Found this here
Thanks Patricia,
That didn't work either as the user hasn't left and is the very same user in the first (working) project.
Very strange.
Thanks, Paul
