How do I avoid double comment to customer when using notifications?
genevieve.vandenhende March 7, 2023
Hi community,
I have set-up customer notifications in Jira. I have amongst others enabled a notification for a status change. However, sometimes a standard text is not enough, and it is necessary to provide more explanation to a customer. When I then type custom text in the comment field, I notice that the customer gets both the template and the text I typed myself.
Is there a possibility that Jira shows the template text when you change the status, but that you can still change it? Or are there other ways to avoid a customer getting 2 notifications?
Dave Mathijs
Hi @genevieve.vandenhende
This means that 2 events are triggered:
  • Public comment added
  • Customer-visible status changed
You might want to disable either of the two, but then you'll need to make a public comment mandatory when changing a customer-visible status.
Hi @Dave Mathijs ,
Thanks for your swift reply. Makes sense. I've tried to disable the public comment notification. However, still double messages appear. This is what I've done:
  • Changed the status to "in progress" with a custom notification
    Works fine - only my custom text appears
  • Changed the status to "pending" without a custom notification
    Now, both the previous status change and the last one appear.
Do you know what is going wrong?
Dave Mathijs
As there are 2 cutomer-visible status changes, there will be 2 customer notifications:
  1. to status "Work in progress"
  2. to status "Pending"
You might consider making these statuses not customer-visible to avoid multiple customer notifications.
So you would suggestd to keep the notifications for a public comment, but disable them for a status change?
